ST 170 Rims on saphire ????????
Does anybody know if the 17" ST 170 wheels will fit on the saph cossie?
If so do you think it will look ok or wot ?
Spoke too some sales bird in a ford garage in leicester she said no, but
i don't think she knew her earhole from her Assh**e........
the offset of the focus wheel is ET49 and the offset on a cossie is ET40 or 41( i can't remember which). the higher the ET no. the further in the wheel is in the arch(if you can understand that) so you would proberly have clerance problems with the shock absorbers, wheel arch liners etc. they proberly would look cool but i have only got one more thing to say about the matter
OZ SUPER Ts
OZ SUPER Ts
might have it the wrong way round, my mind is a bit hazey nowadays it is a long time since i have had to sort out ETs when fitting new wheels to cars.
any way he would still have problems with clerence on the wheel archs, espicelly if the car is lowered.
Is the focus a 5 stud???? I dont know, but the offset of a 4x4 sapph is ET38 I think
so if the focus are ET49 then you are going to need some nice spacers with hub locators so the wheels dont look shit
10 mm spacer.......... that means there's 10 mm less of the hub studs holding on your wheels, may look good but dont corner too hard if you get my drift
JoeyBoyden
Jan 4, 2024 02:36 PM
