fuel pressure
Old Sep 10, 2010 | 10:02 PM
dorrisbjanet's Avatar
dorrisbjanet
Default fuel pressure
hi i have just fitted a set of zzr 1100 carbs to a cvh does anybody know the best way to reduce the fuel pressure have tried a sytec regulator at 1 bar but it is still too high thanks
Old Sep 11, 2010 | 02:49 PM
When I've needed to do the same to SU carbs I've used a malpassi filter king, with in built reg, goes to well under 1psi if needed.
Old Sep 11, 2010 | 07:14 PM
dorrisbjanet
i will get one of these and try it thanks for the info
Old Sep 12, 2010 | 10:00 AM
No probs hope it goes ok.
Old Sep 14, 2010 | 09:48 PM
dorrisbjanet
just fitted filter king it runs a treat now thanks again tabetha for your help
Old Sep 15, 2010 | 03:36 PM
Yay got one right!!
No probs, they work well don't they!!
timsrs
Nov 13, 2018 11:48 AM
A.t.p
Oct 23, 2015 07:54 PM
SMILER258
Sep 28, 2015 09:04 AM
