few bits
started having a clearout will add more when i find it all PLUS POSTAGE
which will only be what it costs
complete bare 2wd manifold freshly powdercoated silver this is just the manifold no sensors etc will inc new set of end cover bolts,slight marks on end cover so will include another free,also powdercoated fuel rail.
will need new gasket set £70 plus postage should imagine around £12 will check
bare 2wd inlet manifold £25 plus postage as above
2wd inlet elbow £10 + p&p
stainless steel battery cover and wrap 265mm by 165 mm just dusty will clean up bufty £20 +p&p
bailey type header tank cap cover £10 +p&p
fuel pressure reg brackets 2wd powdercoated candy red and candy blue
£10 each inc postage
2wd thermostat housing with 2 outlets powdercoated candy blue £20 +p&p PROV SOLD
2wd and 4wd oil cooler modines both have the threaded mounts with them
£20 each +p&p
fuel pump cradle complete in excellent condition just needs a clean £50
+p&p
set of 2wd leads/timing belt/tensioner/oil filter £65 +p&p PROV SOLD
3 door cosworth level 1 stage 3 chips pts only 3 in pic but i do have another one all different programs £45 the lot +p&p
candy red 2wd camcover a couple of minor marks near lifting eyes
camcover only !! £50 +p&p has breather tube fitted>>>>>>>>SOLD
£20 each +p&p
+p&p
TPM961
Jan 15, 2018 10:50 AM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 3, 2015 04:08 PM
