Sapphire Fogs/Surrounds....
Old Sep 8, 2010 | 11:35 AM
Big_Mike's Avatar
Big_Mike
Default Sapphire Fogs/Surrounds....
I have a white saph, with a cut out bumper with a rouse splitter. And I have no fog lights!!
Was thinking about putting some air ducts in, to give it a mean look
Has anybody done this, or have any pics. As I was thinking about putting some fog surrounds and then the air ducts at the back to either the brakes or modifying the air box.
But I think I can only put a duct to the brake on the passenger side, as the washer bottle sits in the way on the drivers side.
The other thing I thought of doing was a grill, similar to the 500, don't know where to get them from etc.
Let me know your thoughts/Advice.
Thanks, Mikey
Old Sep 8, 2010 | 02:20 PM
Ridgey's Avatar
Ridgey
You can cut a hole the size of your duct in the back and fit your tubing to the bumper. Or you could use the location to fit an oil or power steering cooler.
Fix mesh behind the fog lamp surround to make it look decent.
Old Sep 8, 2010 | 03:17 PM
Big_Mike's Avatar
Big_Mike
I did think about some coolers, but it's not going to be used on track, so didn't see the point.
Probably just cut the hole out like you said, attach a air duct, and find something to finish it off.
Mikey
Old Sep 13, 2010 | 05:24 PM
tosh's Avatar
tosh
I'm sure I have seen something like this in Burton's mag which you can cut down to fit, have also seen carbon fibre ones on a couple of sapph's before not sure were to get them from though but look good.
Old Sep 13, 2010 | 06:52 PM
Mikey
There's a big point in a PS fluid cooler, these get seriously hot.
I'm taking my fogs out to put some day running lights in there, I never would use it in the fog, but DRL's are there every second to make you more visible, just my thoughts, using RING AURORA btw.
Old Sep 20, 2010 | 04:50 PM
DaveCrack's Avatar
DaveCrack
I cut up the fog light surround on the back of my bumper and put a oil cooler behind it on one side and a ducting to the airfilter on the otherside + some mesh and black paint to make it look a bit better... Hope this helps.
Old Sep 20, 2010 | 06:32 PM
Das ist sehr schick nicht wa ?
Old Sep 20, 2010 | 09:29 PM
Big_Mike's Avatar
Big_Mike
Yesssssss! That is exactly what I'm looking for
Have you got any close ups, or pictures of it being made?
Cheers, Mikey
Old Sep 20, 2010 | 10:27 PM
tosh's Avatar
tosh
I found this hidden in the depths of my PC, don't know Ho's it is.
Old Sep 21, 2010 | 09:09 AM
Big_Mike's Avatar
Big_Mike
Yes!! That's the one. Thank you very much
Old Sep 21, 2010 | 09:40 AM
J1mbo's Avatar
J1mbo
B1mbo
Like that mate, will speak to you tomorrow when you pop over as know a guy who makes these !!
Old Sep 21, 2010 | 10:47 AM
Big_Mike's Avatar
Big_Mike
Your the man Jimbo!
Rsmat
89
Oct 12, 2015 07:50 AM
Fil
Sep 30, 2015 12:08 PM
tib2220
Sep 14, 2015 12:33 PM
Tony W
Sep 9, 2015 12:08 PM
