mk4 escos 4x4 pic update 1st/9/07
Old Jan 23, 2005 | 08:24 PM
Lloyd's Avatar
Lloyd
escort mk4 cossy 4x4
Default mk4 escos 4x4 pic update 1st/9/07
Old Jan 23, 2005 | 08:35 PM
Lloyd's Avatar
Lloyd
Old Jan 23, 2005 | 08:39 PM
Lloyd's Avatar
Lloyd
Old Jan 23, 2005 | 08:44 PM
Dean Saff's Avatar
Dean Saff
Good work so far..
But how do you get in and out of that garage door...
Old Jan 23, 2005 | 08:50 PM
david's Avatar
david
Looks excellent lloyd, will be a weapon once its done
Old Jan 23, 2005 | 08:52 PM
Lloyd's Avatar
Lloyd
the chap i got it from told me it was a mega bling sunroof i was going to fit it next week
Old Jan 23, 2005 | 09:07 PM
dave cos4x4's Avatar
dave cos4x4
how long lloyd till its done.
Dave.
Old Jan 23, 2005 | 09:13 PM
Lloyd's Avatar
Lloyd
it depends on how much time i can get off work to finish it 4 to 6 weeks at the most
Old Jan 23, 2005 | 09:17 PM
dave cos4x4
not long then.
whats its first outing.
Dave.
Old Jan 23, 2005 | 09:23 PM
Lloyd's Avatar
Lloyd
pts at luton with the central group in march,then central day at the pod on the strip am,and on the stand pm
Old Jan 23, 2005 | 09:24 PM
SPADGE's Avatar
SPADGE
Lloyd what are you going to do about a petrol tank?
Old Jan 23, 2005 | 09:28 PM
Rs Gus's Avatar
Rs Gus
impreza wrx sti version 8
looks mean as get some underbonnet piccys up
Ginge !'s Avatar
Ginge !
just finding my feet
on a serious note theres gonna be a few cossie mk4 escorts about soon
good luck with it mate and keep up posted
Old Jan 23, 2005 | 09:33 PM
Lloyd's Avatar
Lloyd
spadge,when i measure the space left ,where the spare wheel well was,iam gonna get pro alloy to make me one
Old Jan 23, 2005 | 09:34 PM
SPADGE's Avatar
SPADGE
See the thread i just started ref my tank mate! It is only 5 gallons as that is all that will fit!
Old Jan 23, 2005 | 09:51 PM
Lloyd's Avatar
Lloyd
ive been trying to find a pic of the space for a fuel tank,i cant but its loads bigger than a standard cossy tank
Old Jan 27, 2005 | 11:39 AM
adamS2RST's Avatar
adamS2RST
Top work.
Old Jan 27, 2005 | 01:11 PM
Sticky.'s Avatar
Sticky.
Old Jan 28, 2005 | 09:20 AM
Filthy Rich's Avatar
Filthy Rich
Old Jan 28, 2005 | 09:30 AM
Old Jan 28, 2005 | 10:21 AM
Damo V's Avatar
Damo V
How are you fitting up the rear end? cossie setup or axle?
Old Jan 29, 2005 | 06:26 AM
Lloyd's Avatar
Lloyd
cossy rear beam is in and fitted
Old Jan 30, 2005 | 09:44 AM
Damo V's Avatar
Damo V
nice, wouldnt mind seeing how you done it mate...
Im sure i remember seeing pics of this conversion on here or the rsbb years ago didnt I?? the barn type workshop looks familier??
Old Jan 30, 2005 | 09:14 PM
Lloyd's Avatar
Lloyd
yes your right,it has taken nearly 3 years now .good news is i now have the r33 skyline box
Old Feb 5, 2005 | 12:36 AM
mk1 dan's Avatar
mk1 dan
that will be a tool when are u puting more pics up keep looking at this space top job
Old Feb 5, 2005 | 06:50 AM
Lloyd's Avatar
Lloyd
Old Feb 5, 2005 | 06:56 AM
Lloyd's Avatar
Lloyd
Old Feb 5, 2005 | 07:29 AM
Lovin that
Old Feb 5, 2005 | 08:47 AM
Blakey's Avatar
Blakey
Did you build yours in a similar way to how i did mine? (see link.) How are you getting on and are you happy with the work so far, will be starting back on mine in the summer.
https://passionford.com/forum/viewto...er=asc&start=0
Old Feb 6, 2005 | 09:45 PM
Lloyd's Avatar
Lloyd
yes thats how mine was done. and that was the easy bit the rear end is the hard part. brom at zoo makes some nice cos adjustable rear suspension.with a few plates welded in it should be easy to fit a cos rear suspension
Old Feb 7, 2005 | 03:35 PM
Blakey's Avatar
Blakey
how did you do the rear if you dont mind me asking, i was hoping that was going to be easier than the front. have you got anymore pics?
Old Feb 7, 2005 | 07:49 PM
Lloyd's Avatar
Lloyd
if you put the cos rear beam under your escort, you will find that none of the mounting points are near the chassis,i cut out the sierra rear chassis and overlayed it onto the escort,then plated all the gaps.i used 2mm steel plate at the cosworth mounting points.i have some pics but they are too blurred to post.
Old Feb 7, 2005 | 10:08 PM
mk1 dan's Avatar
mk1 dan
very nice just blewn my escort up put a hole in number 1 piston shit happens
Old Feb 9, 2005 | 07:47 PM
Blakey's Avatar
Blakey
lloyd, thats what i had intended to do, i still have the rear mounts for the rear beam from the sierra. thanks for the help mate.
Old Feb 9, 2005 | 08:51 PM
luke89's Avatar
luke89
Team HOTHOT!
looks good so far mate how much left to do ?
Old Feb 10, 2005 | 05:50 AM
Lloyd's Avatar
Lloyd
what shocks are you fitting? coilovers or springs?when are you going to fit the rear chassis? as there are loads of problems.i can save you lots of work my car will be at central day at the pod in april,i can then explain what you will need to do
Old Feb 10, 2005 | 05:52 AM
Lloyd's Avatar
Lloyd
luke,the engine and skyline box are being fitted next monday
Old Feb 10, 2005 | 05:56 AM
Lloyd's Avatar
Lloyd
oh nearly forgot,you will also have to alter the rear inner sill to get clerance for the rear beam
Old Feb 10, 2005 | 11:28 AM
Sticky.'s Avatar
Sticky.
Looking good mate
Old Feb 13, 2005 | 08:35 PM
Lloyd's Avatar
Lloyd
now have a quaif front diff
