rear end clunk!!
Old Jan 23, 2005 | 08:14 PM
righthooker's Avatar
righthooker
Default rear end clunk!!
When pulling away under heavy right foot there is a clunking noise from the rear right of my 3 door ,.I was convinced it was the dif.However today i had the car jacked up and when turning the off side rear(in the air) it would spin freely for about 4" then clunk!!
The near side was ok (no play).
I took the car out and gave it a thrashing and only when droping the clutch dose this hapen if driven normaly it is not evident.
would this be the drive shaft that is worn or something else .
All help appreciated
Old Jan 23, 2005 | 09:08 PM
nicksaph's Avatar
nicksaph
hello mate
i had a similar problem with my old xr4x4 it turned out to be a "dry" cv joint on the back, all i did was pump some fresh cv joint grease in to it and it solved the problem
cheers nick.
Old Jan 24, 2005 | 07:01 PM
righthooker
ok thats one possibility but i think it may not be that simple.!! as i say it has a lot of play and then clunks anyone else??
Old Jan 24, 2005 | 08:09 PM
john_p_b's Avatar
john_p_b
i'm getting a similar thing on my sapphire at the moment too, only really does it on a harsh gearchange when taking up drive of coming off the power suddenly.
i'm thinking it's likely to be a U/J but until the concrete gets above -3 i'm not gonna be crawling under to have a look!
Old Jan 24, 2005 | 09:38 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
rear trailing arm to chassis bushes????? moving when on an off the throtle?
Old Jan 25, 2005 | 07:29 PM
Dean Saff's Avatar
Dean Saff
It does sound like a diff problem, Two options
1) take the back plate off and have a looksee, may find some spare teeth inside.
2)Give it one more Hard launch that will prob finish the fooker off
Old Jan 25, 2005 | 09:43 PM
righthooker
been and done that on sunday still breathing
So ,i have had it up on the ramps at a mates garage and he thinks that the u/v joints are dry,so they all got a good greasing,has quietend down some what.
My mate says that some play on take up is normal and didnt think it was exsesive,so we shall see how it is if the rain ever stops
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
cossirob
Sep 3, 2015 09:17 PM
turbowag
Sep 3, 2015 08:07 AM
