Oil breathers
Old Sep 5, 2010 | 09:39 PM
chrisa3's Avatar
chrisa3
Default Oil breathers
My 2wd sapph has had an aftermarket breather fitted. looking into the connections etc, it looks like it is still plumbed into the standard kidney box. Should this not have been removed, or is it fine to run like that??
Excuse the rough diagram, but this is how its plumbed in on the car. Is this correct??
Old Sep 5, 2010 | 10:18 PM
chrisa3's Avatar
chrisa3
Default update
surely this is connected up all wrong?? does the return to the sump not need to be at the bottom and the breather connections at the middle /top ??
Doesnt the standard kidney breather not vent outwards and not inwards. Ie the pipe running from the bottom of the tank to the kidney is gonna cause a blockage, no?
The one i have label sump, is plumbed into the hole which is usually block off under the exhaust manifold near the rear.
The seperator tank doesnt look like a decent one to start with. Any ideas...
Heres i picture of the tank.
Old Sep 6, 2010 | 10:16 AM
All wrong as you say, there is no right way and wrong way as such just ways that work ways that don't.
The lowest point is where the oil will collect due to the weight of it, so the lowest point is the drain back to the sump, which as you rightly point out MUST be at oil level, ie not open into sump but going directly into the side and joining the other oil, some use the sump plug with an adaptor welded on it for this to connect the return pipe to, the top most one should be the breather itself, the others used for the breather pipe take offs on engine, the kidney box serves a useful function in that it uses a trap/deflector arrangement so a lot of the oil simply hits this and drops back down, leaving the lighter stuff to vent out.
A easy way to make a breather for around £10 is to use a welded up canister, full of stainless steel scrub buds, the things used for scouring pans etc, works perfectly.
Nov 1, 2015 06:53 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
DAZZER
Sep 30, 2015 08:43 PM
Fudgey
21
Sep 30, 2015 06:19 PM
