ht leads are wrong
Old Sep 5, 2010 | 02:57 PM
Rs Baz's Avatar
Rs Baz
Default ht leads are wrong
guys ive just fitted a new dizzy cap and leads but i think there wrong
its a saph cosworth 4x4, on the top of the cap it has numbers for the leads ive done this but it has a bad misfire i.e leads being wrong..
as you look at it from top numbers are like this
43 12 coil in middile
starting from top left what are the numbers please
top left
top right
bottom left
bottom right
it may be somethig else thats wrong the car hasnt been used since dec 08
also where can i get the fan loom from i was going to make my own but dont know where to get the relay connector from
Old Sep 5, 2010 | 04:09 PM
Rs Baz's Avatar
Rs Baz
anyone ????????
Old Sep 5, 2010 | 07:44 PM
Relay connectors can be got from people like www.vehiclewiringproducts.co.uk
To do the HT leads simply put engine at TDC as marked on crank pulley, with cam pointers pointing inwards, ie exhaust at 3 o'clock and inlet at 9 o'clock, then note where the rotor arm points to that's number 1, 3 is next, then 4 then 2, as firing order is 1/3/4/2, 99.9% sure the dizzy rotates clockwise but check.
Old Sep 6, 2010 | 12:11 AM
Rs Baz's Avatar
Rs Baz
thanks for that mate something isnt right still, it still has a misfire
Old Sep 6, 2010 | 10:07 AM
Determine which cylinder is missing first by pulling leads off with engine running, if you don't like shocks use something insulated to do this, if you have any heart condition let someone else take the shocks.
Then you can test lead, plug, cap etc to narrow down.
Old Sep 7, 2010 | 09:31 AM
saph-mad's Avatar
saph-mad
mine at the this at the min done all of the above its off on no 4 but its getting spark and fuel ? any help ?
Old Sep 7, 2010 | 06:27 PM
Just for peace of mind do a compression test, it could still be a lead or plug, when outside the engine they need a lot less power to make them spark, compared to in the engine under compression, this has the effect of trying to kill the spark, why some lose the spark only under boost, ie increased compression(adiabatic) ratio.
You can always do swapsies with the lead or plug into another known good cylinder to see the effect of the swap.
Old Sep 9, 2010 | 12:02 AM
Rs Baz's Avatar
Rs Baz
still got the same problem i need to make sure the leads are correct before i pull any leads off
Old Sep 9, 2010 | 01:16 PM
martysmartie's Avatar
martysmartie
Easiest way is to label the leads.
Martin
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
A.t.p
Oct 23, 2015 07:54 PM
The Youth.
Sep 30, 2015 09:59 PM
DavidK
Sep 27, 2015 02:55 PM
