Would a full set of seats fit into a normal 96 1.8 sport? Only difference i see is that the driver and passenger fold forward as there from a 3dr where as im looking them for a 5dr?
Yes should fit straight in, although you may need to swap front seat runners over if they don't fit, due to 3/5 door. Make sure that wiring for airbags etc are the same too. Disconnect battery before unplugging seats or airbag warning light will come on!
