Cosworth cooling on track
Old Aug 31, 2010 | 12:35 PM
Trist's Avatar
Trist
Default Cosworth cooling on track
Having problems getting engine temps down. We are here now with 2. Both 4x4s. One with 240bhp no issues and one with 430 is getting hot. Got headlights and gril out. Any other options?
Thanks
Old Aug 31, 2010 | 12:48 PM
Dirty Harry's Avatar
Dirty Harry
Super Moderator
Thanks
oil cooler and a better rad
Old Aug 31, 2010 | 12:55 PM
R4N SS's Avatar
R4N SS
is it an ally rad?
Old Aug 31, 2010 | 12:57 PM
Dirty Harry
Super Moderator
also check your water pump to make sure its a genuine item
Old Aug 31, 2010 | 01:17 PM
Trist's Avatar
Trist
Air tec ally rad oil cooler fitted. Hot on track. Come in let it run and it cools down. When it's hot, cool air comes out blowers. When it cools hot comes out
Old Aug 31, 2010 | 02:20 PM
R4N SS's Avatar
R4N SS
i reckon its the rad - never been a fan of ally rads.
try putting std rads in. Mike (Boxxer) had a similar thread about this last week)
Old Aug 31, 2010 | 02:40 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
best mod i made to mine to keep the temps down was a turbo pre rad but i also have a 50mm core ally rad and mapped water injection for when the charge temp gets hot
Old Aug 31, 2010 | 02:51 PM
RichieST's Avatar
RichieST
Something doesn't sound right there then!
Old Aug 31, 2010 | 03:00 PM
Dan@Rapid-Ford's Avatar
Dan@Rapid-Ford
The tubes on core on the Airtec rad are too big they are not cooling enough.
If you look at a std rad core and compare to an intercooler core they are different for a reason.
Then look at the Airtec products and they all use the SAME core.
Old Aug 31, 2010 | 03:06 PM
R4N SS's Avatar
R4N SS
nice one Dan - so it IS the ally rad.
Old Aug 31, 2010 | 04:01 PM
Dan@Rapid-Ford
Its not a conclusive answer no - but more of an observation
If OE manufactures use different cores for air/water/oil and all the other aftermarket suppliers use different cores depending on applications........
Old Aug 31, 2010 | 06:52 PM
Spiky's Avatar
Spiky
my 350 saff, never got hot on track and that was using a std OE rad,
your rad might be blocked or you got an air lock
try a known good rad and see
on the 4x4 check the thermostat
Old Aug 31, 2010 | 06:58 PM
Danny @ Enhanced Performance's Avatar
If its got cold air when the cars hot and vice versa its got leakage issues!!!!
Check head gasket or heater matrix..
Never had probs with the airtec rads..
cheers danny
Old Sep 1, 2010 | 08:42 AM
R4N SS's Avatar
R4N SS
i had a std rad at 400bhp and never had any issues at all either
Billy_RS
16
Oct 11, 2025 09:41 PM
SmudgerByName
52
Jul 28, 2016 06:14 PM
lukeeboy149
Aug 22, 2015 04:29 PM
Aug 14, 2015 07:29 AM
Old ford
Jul 31, 2015 06:50 AM
