Oil press gauge sonection on 4x4 sierra coswarth
Old Aug 30, 2010 | 05:15 PM
Miles...'s Avatar
Miles...
Cool Oil press gauge sonection on 4x4 sierra coswarth
Can someone tell me where can I connect the oil press gauge,somewhere not near the press switch!!!
cheers guys
Old Aug 30, 2010 | 06:11 PM
Cylinder head, at the rear of the head is a blanking plug in each oil gallery, also at front but pulley is in the way here.
T piece on the turbo oil feed pipe, machine jackshaft/auxillary cover and tap into oil gallery there, take a tapping on the other side of the head in the centre of the oil gallery.
Loads more places if using oil cooler ie sandwich plate or pipe.
Old Aug 30, 2010 | 11:33 PM
kosienutter's Avatar
kosienutter
Last Time, Get Off PF FFS
best thing imo a sandwichplate between the oil filter and filter arm to the block bit. They usually have a couple of connections so whilst your at it fit an oil temp one too. That way i know then once the oil is up to normal running temps i can put my foot down safely.
Old Aug 31, 2010 | 01:56 PM
Miles...'s Avatar
Miles...
Cheers guys, 10x for your time
andyrs1600i
Aug 30, 2015 07:21 PM
Adam-M
Aug 26, 2015 05:53 PM
mrmann
Aug 20, 2015 11:24 PM
Vincereese
Aug 15, 2015 06:24 PM
Vincereese
Aug 11, 2015 08:44 AM
