mk6 escort hunting
Old Aug 30, 2010 | 04:19 PM
turbobill's Avatar
turbobill
Default mk6 escort hunting
my mk6 escort 1.6 is hunting on idle, ive changed the air flow sensor and the tps sensor, that seems to have cured it but now if i dip the clutch it stalls, then i bring the clutch up and it goes again, so ive disconected the tps sensor atm and its running better, but is it ok to keep it disconected? until i get a new one also if it does start hunting again could it be the idle valve ??
sorry for the essay
Old Aug 30, 2010 | 07:52 PM
turbobill's Avatar
turbobill
anyone??
Old Aug 30, 2010 | 09:50 PM
yellowsierra's Avatar
yellowsierra
Dude
Try disconecting and reconecting the Battery so the ecu can reset from the faults
The ivc will hold the revs up and cause it to hunt
Old Aug 30, 2010 | 10:10 PM
phil_focus's Avatar
phil_focus
pcv valve causes hunting hen they get old and gunged up so worth replacing that.
disconnect the battery for half hour then reconnect, start engine and allow to warm up on its own.
if yu suspect the tps fo the stalling issue refit the old one and try that.
Old Aug 31, 2010 | 08:00 PM
turbobill's Avatar
turbobill
thanks for that, i did disconnect the ecu , il try these next tho, cheers
rex647
Mar 6, 2022 06:20 AM
Dr. Ickxs
Sep 15, 2015 10:15 PM
bassboy
Sep 10, 2015 08:54 PM
imnoteasy
Sep 7, 2015 09:26 PM
