How much power is put to each prop? MT75 4x4
is there anyway of changing it or having some sort of lsd in the box?
reason being im using the gearbox on a project car im building with engine + box in the back, rear prop going to the front + front prop going to rear diff
cheers
james
cheers
james
so your building a mid engined car with an mt75? there was a thread on here not long back about the gbox options for an rs200 replica.
it has been done before, but gives the car weird characteristics.
have a read of this
http://www.pistonheads.com/gassing/t...20set%20up%20?
have a read of this
cheers for all the replies guys + the good luck
Yes, rear engine onto an mt75 4x4, frt prop to rear diff + rear prop to front diff + turn both diffs upside down due to the props spinning oposite way ino the diffs as engine in back
66 front 34 rear would mean 66% is going to the front wheels which is oposit to what i need, best search for a way to locking centre diff or a changing the percentages, ive got a feeling its not going to be easy though
Doesnt seem like theres any other gearboxoption though
James
have a read of this
have a read of this
James
thats something else im trying to find out, some diffs + casings are fine upsite down + some arnt, trying to find any pics of the inside diff casing to see whether it would be ok or not
kyle_st200
Ford Focus Diesel
Aug 21, 2015 09:28 PM
