T5 box leak???
Old Aug 28, 2010 | 02:31 PM
tigra turbo's Avatar
tigra turbo
Default T5 box leak???
This is non for but from vaux westy but using a T5 box,thought u will be the best people to ask,as u used those boxes alot
seems i have a leak from it,,,,,any gen were from??
Old Aug 29, 2010 | 07:30 PM
tigra turbo
any one
Old Aug 30, 2010 | 09:28 AM
COLEYST200's Avatar
COLEYST200
its very hard to say were its coming from mate you will need to clean as much as poss off the box go for a small drive and then see were its coming from thats the best i can say about it
Old Aug 30, 2010 | 11:32 AM
The Crocodile Hunter's Avatar
Could be worth having the starter motor out to see if there is loads of oil inside the bell housing?? may just be the input shaft seal??
Old Aug 30, 2010 | 12:34 PM
tigra turbo
Thanks for the recommendetions
timsrs
Nov 13, 2018 11:48 AM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Steve Escos
Oct 1, 2015 06:57 AM
Fudgey
21
Sep 30, 2015 06:19 PM
Russ Payne
Sep 25, 2015 08:29 PM
