Kill Switch Behind Bumper **Now with Photos**
Old Aug 27, 2010 | 10:31 PM
Sonic Boom's Avatar
Sonic Boom
Default Kill Switch Behind Bumper **Now with Photos**
What does the kill switch behind the bumper turn off, (I take it is a kill switch looks like a push button mounted just behind the bumper)
Does it kill the fuel?
Cheers Rich
Old Aug 27, 2010 | 10:39 PM
jon@work's Avatar
jon@work
you sure it's not an outside air temp sensor ?
Old Aug 27, 2010 | 10:43 PM
Sonic Boom's Avatar
Sonic Boom
Definatley a push button but I don't want to push it, but i'm afriad it maybe the reason my car wont start just need to know what it kills.
Rich
Old Aug 27, 2010 | 11:20 PM
BRAMMER's Avatar
BRAMMER
On the 3dr Rich??? can't remember seeing one on mine
Old Aug 27, 2010 | 11:30 PM
Sonic Boom's Avatar
Sonic Boom
Yup, this slightly worrying.
I'll take a photo in the morning.
Rich
Old Aug 27, 2010 | 11:56 PM
SS1's Avatar
SS1
Is it a button or a switch make your mind up
Most prob immobiliser start the car then push it in or click it
"disclaimer" if your engine blows up dont blame me
Old Aug 28, 2010 | 09:34 AM
Well it's defo not a std ford fitment, just push the thing easiest way to see if it has any effect.
Old Aug 28, 2010 | 09:45 AM
Sonic Boom's Avatar
Sonic Boom
It looks like one of those crash type ones you know once it's pushed thats it no reset.
Rich
Old Aug 28, 2010 | 09:48 AM
martysmartie's Avatar
martysmartie
Does it have a pivot bar that pushes down and is nearer the right hand side or centre of the car, if so I am certain thats the temp sender for the graphic display.
Martin
graham c's Avatar
graham c
fuel cut off arnt they in the boot ?
Old Aug 28, 2010 | 09:52 AM
martysmartie
3DR dosen't have one at all, 2WD yes, I think 4x4 has them inside the car, certainly not at the front of the car.
Martin
Old Aug 28, 2010 | 10:25 AM
Sonic Boom's Avatar
Sonic Boom
Soz about the poor quality taken with my iPhone
Here's a close up even has a Ford Stamp and it's wired into the main car loom along with the lights:
Its mounted just to the right hand side of the fog light grill (if your looking at the car from the front) You can't really make it out in the photo:
Rich
Old Aug 28, 2010 | 10:27 AM
m4tt274's Avatar
m4tt274
never seen one of those before :S
Old Aug 28, 2010 | 10:31 AM
steves24V's's Avatar
steves24V's
gotta be a outside temp sensor but didn't think 3drs had temp read outs, is is def a button does it press in
Old Aug 28, 2010 | 10:34 AM
Sonic Boom's Avatar
Sonic Boom
Ye it's definatley a button, just don't want to risk pressing it.
Rich
Old Aug 28, 2010 | 10:37 AM
Cragrat's Avatar
Cragrat
sit boo boo sit
got one on mine too,i thought it was a fuel cut off switch
Old Aug 28, 2010 | 10:44 AM
graham c's Avatar
graham c
press it ?
Old Aug 28, 2010 | 10:49 AM
m4tt274's Avatar
m4tt274
trace the wires from it?
Old Aug 28, 2010 | 11:02 AM
Sonic Boom's Avatar
Sonic Boom
Bugger that i've just rewraped the whole car loom.
Rich
Old Aug 28, 2010 | 11:32 AM
martysmartie
Thats the one I mentioned earlier, I am 99.9% sure thats for the temp part of the graphic display module.
Martin
Old Aug 28, 2010 | 11:35 AM
daviddunlop83's Avatar
daviddunlop83
3 Doors had a frost warning light do they not? so they must have a temp sensor somewhere.
Old Aug 28, 2010 | 11:40 AM
RichieST's Avatar
RichieST
afraid I can't help, but it reminds me of at work there's a doorbell on a counter so you can call someone over, someone remade the sign so it read, 'press here to blow up the world'
No one ever pressed it again
Old Aug 28, 2010 | 12:01 PM
Gav Diamond's Avatar
Gav Diamond
This is the outside temperature sensor mate.
Old Aug 28, 2010 | 12:07 PM
Rob_DOHC's Avatar
Rob_DOHC
Press it.
Old Aug 28, 2010 | 12:23 PM
Sonic Boom's Avatar
Sonic Boom
I've pressed it and it does bugger all but the car won't start anyways.
If its a sensor why does the button depress?
Rich
Old Aug 28, 2010 | 01:17 PM
martysmartie
Thats because it's not a switch, it's a sensor the bit you see on it which depresses is a thermistor, I guess the question was in aid of a problem with it not starting?
Martin
Old Aug 28, 2010 | 01:40 PM
COLEYST200's Avatar
COLEYST200
http://cgi.ebay.co.uk/FORD-OUTSIDE-A...-/360096735299
Old Aug 28, 2010 | 03:47 PM
BRAMMER's Avatar
BRAMMER
Is there power at the pump??
Old Aug 28, 2010 | 04:02 PM
Sonic Boom's Avatar
Sonic Boom
Yup, i've given up tring now hopefully go down to Reyland next week.
Rich
Old Aug 28, 2010 | 04:11 PM
Easy way to tell is write down part number and see what ford call it, can't see that being the frost warning, any thermistor would need better ambient than inside that device would give, and certainly wouldn't have or need a press button on it.
Wire colour would give a clue though.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
boeb
Jan 9, 2020 05:11 AM
rsguy
44
Sep 29, 2015 03:29 PM
cossie330
Sep 27, 2015 04:13 PM
