4x4 MT75 + diff strength?
Old Aug 27, 2010 | 11:36 AM
Jamesvfr's Avatar
Jamesvfr
Default 4x4 MT75 + diff strength?
Hi all
Im building a bit of a project car + will most likely using 4x4 mt75 box with cossie diffs
Just wondering how much power box + diffs will take?
Front diff will have the strengthening plate fitted
The car will only be weighing approx 1000kg + i want to running at least 400bhp
ive heard 350bhp being the limit for the box but wondering as the car is lighter than a sierra or escort it may well be ok with the power
thanks for any replies
James
Old Aug 27, 2010 | 03:31 PM
ECOS95's Avatar
ECOS95
It's the high torque that kills 3rd gear, you may be ok depending on your setup. MT75 boxes can be had quite cheaply these days so could be worth trying a good standard box & see how it goes. No point upgrading if its not needed.
Old Aug 29, 2010 | 10:00 PM
Jamesvfr's Avatar
Jamesvfr
as you say they are getting cheap + as the bellhousing is being modified i could always use the xr4x4 mt75 as they seem to be cheaper
any idea on diff strength?
cheers for your reply
James
Old Aug 29, 2010 | 10:12 PM
m4tt274's Avatar
m4tt274
you can buy diff strengthening plates fairly cheap, and about 380bhp is where id imagine they will start going wrong.
Old Aug 31, 2010 | 10:54 AM
ECOS95's Avatar
ECOS95
Heard of people running 400BHP with a standard front diff with a plate fitted. They only see 34% of the power but it depends on how hard a life its had. 2nd hand diffs can be had for £50 upwards so very cheap in comparison.
Best bet is get the box & diffs rebuilt so you know you have a good starting point.
Old Sep 1, 2010 | 10:05 PM
scarabman's Avatar
scarabman
its not a case of how much bhp an mt75 can handle,its the torque which is the important factor.anything over 350 ftlbs of torque is pushing the mt75.I have sheared of 3rd gear teeth with well over 400ftlbs of torque but my car has only 300 bhp.
personally i dont think its the front diff case that is a problem,it's the strength of crown and pinion teeth.how can fitting plate make the gears stronger!! the gears break off then wedge themselves between the crown and pinion, then it breaks the diffcase.
Old Sep 1, 2010 | 10:23 PM
m4tt274's Avatar
m4tt274
the front diff cases flex and cause the teeth to move out of place on each other that then causes what you have described.
Nov 1, 2015 06:53 PM
mjonathan24
Oct 29, 2015 10:39 PM
Iain Mac
Sep 30, 2015 09:39 PM
DavidK
Sep 27, 2015 02:55 PM
