saph cossie is kangarooing
Aug 26, 2010 | 12:33 AM
the car starts jerking when i go over a bump or hit a pothole , only for a second and the rev counter drops to zero as i lose all power but comes back to life quickly afterward anybody know what this might be cheers
Aug 26, 2010 | 06:50 AM
sounds like it a electrical problem check all connections mate and ohms on sensors do the wiggle test on the loom as maybe a broken wire
Aug 26, 2010 | 07:37 AM
Could be ecu feed multiplug, mine done the same!
Cheers shaun
Aug 26, 2010 | 09:32 AM
Defo sounds electric problem, check obvious things like coil connection also, as said the wiggle test is going to be most use here.
Aug 26, 2010 | 10:14 AM
ya its after getting really frequent last night so the wiggle test should hopefully pick it up
Aug 26, 2010 | 08:05 PM
Yank the steering wheel adjustable reach in/out a couple of times, there can be loose connections there.
Aug 27, 2010 | 12:47 PM
I suspect the CPS from what you said also about the tacho, the connector pins often loose there grip, again the wiggle test would confirm this.
Martin
Aug 27, 2010 | 09:27 PM
Rsmat
89
Oct 12, 2015 07:50 AM
gcfcos
59
Oct 6, 2015 05:04 PM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Russ Payne
Sep 25, 2015 08:29 PM
