mot and emissions results
Old Aug 25, 2010 | 02:27 PM
eoeumc's Avatar
eoeumc
It's ALIVE..Well sort of!
Default mot and emissions results
Hi folks
My car actually passed its mot today (third time lucky)
And I'm asking about the emissons results I got.
They were in the pass level but the car needs something to make them better and make the car feel/run right
The results were:
CO- Max 3.50% actual- 0.11%. Very low
HC- Max 1200ppm actual- 1156ppm. Very high and just in the limit
So what does the car need to help these out etc?
Thanks peeps
Old Aug 25, 2010 | 03:06 PM
oldford's Avatar
oldford
What kind of car is this? What kind of injection?
Do you also have the figures for CO2, O2 and the lambda number?
Old Aug 25, 2010 | 03:09 PM
phil_focus's Avatar
phil_focus
more details needed.
what car and engine? any mods?
and the rest of the emmisions results.
Old Aug 25, 2010 | 06:20 PM
eoeumc's Avatar
eoeumc
Sorry peeps
Its an RS converted MK4 Escort Cabriolet. 1989 "G" reg.
As for the rest of the results, that is it I'm afraid.
Apart from idle speed- pass and smoke level- pass! lol
That's all that's on the sheet
And yes it is de-catted
Old Aug 25, 2010 | 06:46 PM
The reason it only just scraped through is because it is running so lean, leading to a lot of unburnt fuel in the exhaust, this is your PPM, it will be much higher if running too lean, as a rough guess I'd expect from yours nearer 2 % CO, and 100-300 ppm.
Old Aug 25, 2010 | 06:58 PM
eoeumc's Avatar
eoeumc
So what would it need doing to be able to get to your estimates?
Old Aug 26, 2010 | 10:03 AM
It needs to be made richer, try turning the idle co screw, assume you have the std mfi, if which case insert a long 3mm allen key down the "tube" at the side of the air elbow on top of the fuel flap area, and turn, tbh this would be best done in a garage unless you have the means to measure it ?
You'll also find it drives vastly better as well.
Nov 1, 2015 06:53 PM
