Logo
most will have a go for free mate, get the details up and see what peeps produce.
Ideal info is:
Company name
strapline if there is one
type of business
type of target market
colours prefered
also, the use of the logo ie signs, vans, clothing, leaflets and letterheads, web etc etc (keeping in mind if it is going to be used large then it needs to be a vector so as to scale easily, or clothing may have implications on detail, and how many colours you want it.
Even if you dont get the finished article off here, if you get something close you can take to a designer, it will cut costs dramatically with a designer.
Ideal info is:
Company name
type of business
colours prefered
easy enough to add .com to it mate, will have a look when I am next back in work, would have the .com smaller a bit like Mach has done so as not to be overpowering.
If you pm me your email address I will send you eps,pdf and jpeg files so that you can take it to local printers etc and they can edit it and use it to make the items you need.
Matt
Matt
For embrodering you should of cause use the 2-color version as shown, which is normal for business these days, a more detailed and gradient filled logo for use on web, print and so on, and a more simple version, mostly a 1- or 2-color version of the logo for embrodering, offset print etc.
Let me know if you like it, and if we should do more...
- Mach
Mach01.com
lee peneycad
Nov 27, 2004 08:02 AM
Thrush
Oct 19, 2004 06:34 PM
Stu @ M Developments
49
Oct 3, 2004 11:21 AM
