rear arms
Old Aug 24, 2010 | 01:13 PM
dingla rs's Avatar
dingla rs
Default rear arms
are 2wd and 4x4 rear arms the same ,just have change the hubs ? cheers
Old Aug 24, 2010 | 02:39 PM
155lee's Avatar
155lee
think its only 3 door arms that are different,where the arb is located is the difference.
Old Aug 24, 2010 | 04:30 PM
What he^^^ said.
Old Aug 24, 2010 | 04:58 PM
dingla rs's Avatar
dingla rs
what bout hubs then ,just i got 2wd arms hubs ,and i can get just the beam for next to nowt thanks
Old Aug 24, 2010 | 05:28 PM
155lee's Avatar
155lee
the rear beam on the 4x4 is narrower where the diff mounts i just remembered.if you are using the 4x4 beam and 2wd diff you need to shave a tad from the top mounting hole of the diff.easily dont but the diff will need some washers if it ever goes back into a 2wd beam.sure the hubs are the same,cant see any reason why they would be.i had some 4x4 rear hubs and flanges,sold them to a guy with a 2wd,remember him saying they would fit.never heard back so they must have.
Old Aug 24, 2010 | 05:54 PM
dingla rs's Avatar
dingla rs
im using a 4x4 diff and beam,and want to use 2wd arms and hubs as i have them laying round its for my focos 4x4 thanks guys for info ,not clued up on cossies
Old Aug 24, 2010 | 08:32 PM
155lee's Avatar
155lee
yeah,that will work.i think the driveshafts are all the same between 3dr,2wd and 4x4.
Old Aug 24, 2010 | 08:39 PM
paul16v's Avatar
paul16v
Monte 087
2wd shafts are fatter and have bigger flanges than 4x4 ones.
Old Aug 24, 2010 | 09:00 PM
dingla rs's Avatar
dingla rs
i have 4x4 shafts will they fit the 2wd hubs then
Old Aug 25, 2010 | 09:23 AM
PAUL S's Avatar
PAUL S
no, you will need 4x4 outer splines but the outer hub with the 4 studs, and the bearing carrier are the same on 2wd and 4x4
I have 2 spare 4x4 splines if you need them, pm me if interested - can post
155lee
Oct 27, 2015 04:55 AM
Fudgey
Sep 17, 2015 01:06 PM
Tony W
Sep 9, 2015 12:08 PM
rsturbo27
Sep 5, 2015 05:08 PM
