suspension whats best?
Old Aug 23, 2010 | 09:04 PM
englandtillidie's Avatar
englandtillidie
Default suspension whats best?
hi all, have decided to give my escos a bit of a change and 1 of the things is lowering, but am unsure which to go for, is it worth going for coilovers or just stick with normal konis etc, would like alloys to sit inside arch's how low would i have to go am running 18in rondells
cheers
Old Aug 24, 2010 | 02:52 AM
CRAIG HAYTER's Avatar
CRAIG HAYTER
depends oon these things
1.do youu want a bumpy ride?
2.do you want to be constantly cleaning coil overs as they get rusty as fk
3.how much you looking too spend because good coil overs are £850 upwards
i have konni's and eibach springs very comfy and easy to clean as i was going to go coil overs but rubbered it as they get rusty as fk
koni's and ahamed bajoo springs are really good avalible from Mike Rainbird RnB motorsport
Old Aug 24, 2010 | 05:37 AM
pete mcrash's Avatar
pete mcrash
saff is working!!!...atm
and remember lowering these cars doesn't improve the handling
Old Aug 24, 2010 | 10:08 AM
m4tt274's Avatar
m4tt274
lol, you just cake them in grease when u fit them and then re apply every now and again lol, or do what i did and just spray them with a rattle can silver, then when u want to sell them wipe it all off with thinners and they look brand new.
i have koni's and eibach springs on the p100 and although its the same running gear, the back end obviously will act differently to an escos, it does handle well and doesn't knock your teeth out (y)
Old Aug 24, 2010 | 10:17 AM
YBT200's Avatar
YBT200
i have koni's and ahmed bajoo springs which handle good, and the ride is good also.
Old Aug 24, 2010 | 04:27 PM
Dave Hewy's Avatar
Dave Hewy
As above, koni's and ahmed springs is meant to be the best setup. I have konis and unknown springs and i love the handling and the stance is awesome.
Old Aug 24, 2010 | 06:55 PM
ECOS95's Avatar
ECOS95
I went for the Koni & ahmed setup on mine, very pleased with it.
Old Aug 24, 2010 | 08:09 PM
englandtillidie
cheers people looks like koni's the winner
Old Aug 25, 2010 | 03:03 PM
ECOS95's Avatar
ECOS95
What size are the wheels you're using?
If they're 18"x8.5" you'll need to adjust the spring cup seat (From previous experience).
Old Aug 25, 2010 | 07:20 PM
englandtillidie
off top of my head not sure know its 18 but will have to check if 8.5 cheers for the heads up
Old Aug 27, 2010 | 03:26 PM
ECOS95's Avatar
ECOS95
No probs, nothing a BIG hammer won't fix.
Nov 1, 2015 06:53 PM
SMILER258
Sep 28, 2015 09:04 AM
