focus rs servo&master cylinder/resevoir work with a FRST
Old Jan 22, 2005 | 07:11 PM
rich_frst's Avatar
rich_frst
Default focus rs servo&master cylinder/resevoir work with a FRST
Does anyone know if it would be possible to use a focus rs servo and master cylinder/resevoir (that has abs) with the same brake set-up in a fiesta turbo minus the abs...
anything is possible and it could be made to fit, but would there be problems as its come from a car with abs, and is going onto a car without...
any help would be very grateful
cheers
Old Jan 23, 2005 | 10:10 PM
ses's Avatar
ses
Hmm.. I don't know anything about this, but I pity the FRS who gave it's life in order for this to be a possibility :-(
Old Jan 23, 2005 | 11:18 PM
Lord Lucan MK's Avatar
Lord Lucan MK
It would work as long as you use the harness as well but the main problem wouldd be that the ABS would not work properly without the calipers front (Brembos) and rear cause ithink that the system runs on the pressure values of the fluid and as your calipers are totally different this may cause it to pack up on you leaving you back to as it was you maybe better off with a 4x4 sapph set upas this has been done before
Old Jan 24, 2005 | 06:27 AM
rich_frst's Avatar
rich_frst
Old Jan 24, 2005 | 06:34 AM
rich_frst's Avatar
rich_frst
the only reason i'd use the FRS servo, master cylinder and servo was if i had the 'same brake set up' (brembo's and rear discs)... but taking the abs off my FRST, using the FRS brake setup(servo,master cylinder and resevoir) and having it without ABS would that be a problem?!?
Old Jan 24, 2005 | 07:23 PM
Lord Lucan MK
dont really think i would want to find out to be honest cossie set up is a better way to go and maybe use 2wd 4 pots
original
Apr 28, 2026 05:20 PM
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
Caddyshack
Aug 19, 2015 07:29 PM
