2wd and 4x4 suspension...
Old Aug 23, 2010 | 12:21 PM
Toe Knee's Avatar
Toe Knee
Default 2wd and 4x4 suspension...
Can u fit 4x4 suspension on a 3door can't remember?! Mate has seen some and wanted to know if they will fir his 3 door or not
Old Aug 23, 2010 | 12:54 PM
Front struts are a problem as the 4wd are thicker diameter bodies, if the other way around you could just use a sleeve to join 2wd struts into 4wd hubs.
The rears will be ok can be used, the lower eye mounting is roughly 1/2" wider on the 4wd but can chop off 1/4" each end of the eye tube and it fits right on.
Old Aug 23, 2010 | 01:34 PM
Toe Knee's Avatar
Toe Knee
Cheers dude will let him know
Nov 1, 2015 06:53 PM
cossie330
Sep 27, 2015 04:13 PM
DavidK
Sep 27, 2015 02:55 PM
mpilk
Sep 27, 2015 09:21 AM
Russ Payne
Sep 25, 2015 08:29 PM
