Cosworth turbo rebuild difficulty level??!
Old Aug 23, 2010 | 08:40 AM
Djed710's Avatar
Djed710
Djed710
Default Cosworth turbo rebuild difficulty level??!
Hi. I'm after some advice! The turbo on my cosworth needs reconditioning as it is letting alot of oil past the seals and it has quite alot of play in the shaft. Is it a job I will be able to so myself or am I best sending it to a specialist and paying for it to be sorted. I'm a ford mechanic n reckon I could hav a good go at it but wondered if anyones familiar with what it involves n could tell me whether it's a nightmare job or anything! Kits are cheap in comparison to sending the unit somewhere to be fixed so obviously would prefer to do it myself if possible! Thanks for any replys.
Ed
Old Aug 23, 2010 | 09:05 AM
RS500/364's Avatar
RS500/364
tbh i would go for a rebuild as you might only get charged Ł200-300 with a warrenty and balanced so will last if you intend to keep !
Old Aug 23, 2010 | 01:02 PM
That's what I'd do as well, get a 360 bearing and step gap seal done at the same time whilst it is being done.
Old Aug 23, 2010 | 05:18 PM
Djed710's Avatar
Djed710
Djed710
Thanx for the advice. Il get saving up then and get it sent away! Next question is can anyone reccomend anywhere? I'm near Preston Lancashire.
Thanx again
Old Aug 23, 2010 | 05:38 PM
cossyking's Avatar
cossyking
Thanx again
i always use cr turbos they will collect and deliver and turn the job around very quick
big_Rad
Sep 15, 2017 09:36 AM
CLIVE
Oct 2, 2015 12:58 PM
djmca
Aug 20, 2015 08:26 AM
IAN RS2k
Aug 18, 2015 07:51 PM
Aug 14, 2015 07:29 AM
