focus 1.8 misfire problem
Old Aug 22, 2010 | 05:44 PM
jasonnjane's Avatar
jasonnjane
Default focus 1.8 misfire problem
just got this focus last week and it has just developed a mis fire...
took plug leeds off and the spark plug holes were full of water and tried that once cleaned water out and i got a right smell of burning plastic...stopped and the lamba sensor wires had touched the manifold and shorted together...seperated then and insulated them and it still miss fires...
any ideas anyone?
Old Aug 22, 2010 | 05:48 PM
oldford's Avatar
oldford
Fuse blown for the Oxygen sensor heater?
Where's the water coming from?
Old Aug 22, 2010 | 05:51 PM
jasonnjane's Avatar
jasonnjane
Oxygen sensor heater...where would i find that fuse location?
water was from me giving it a clean...yard at work so dusty.
Old Aug 22, 2010 | 06:12 PM
jasonnjane's Avatar
jasonnjane
Old Aug 22, 2010 | 06:45 PM
martysmartie's Avatar
martysmartie
Fuse 18 (10A Engine Compartment)
Martin
Old Aug 22, 2010 | 07:13 PM
jasonnjane's Avatar
jasonnjane
well fuse was blown...thanks martin...but still has the mis fire...
once it gets revving its ok,just low revs it has naff all power.
Old Aug 22, 2010 | 07:43 PM
jasonnjane's Avatar
jasonnjane
also i unplugged the lamba sensor plug while engine running and it made no difference so i'm now wondering if the lamba sensor is goosed.
Old Aug 22, 2010 | 07:47 PM
oldford's Avatar
oldford
Probably. Have the live data read by someone with the right equipment.
But could also be some water left in one or more connectors.
Old Aug 22, 2010 | 07:49 PM
jasonnjane's Avatar
jasonnjane
the water was in the holes for the spark plugs and is all dry now.thing is i am off to work in it in morning...got a 3 hour journey to get there too..hate working at different depots!
Old Aug 22, 2010 | 08:24 PM
martysmartie
More than likely either that or the wiring has a break where it melted, the lamba are common for problems though so it may be worth replacing.
Martin
Old Aug 22, 2010 | 08:31 PM
jasonnjane's Avatar
jasonnjane
wires looked ok.still copper colour and looks like i will have to replace lamba sensor in morning...gonna be late for work but what can i do!
Old Aug 22, 2010 | 09:02 PM
martysmartie
They can be extremely tight due to the heat, patience is a virtue
Martin
Old Aug 27, 2010 | 08:32 PM
jasonnjane's Avatar
jasonnjane
well sorted problem...was coil pack and wires on lamba sensor were ok and just both happened at same time..
cars running fine now...
its for sale too lol
j.hammond1
30
Oct 31, 2021 05:28 PM
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
da52rkn
Ford Focus Range
Aug 21, 2015 04:41 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
taylora1409
Aug 12, 2015 12:06 PM
