Which fuel pressure regulator?
Old Aug 22, 2010 | 12:55 PM
Karl 3dr's Avatar
Karl 3dr
Default Which fuel pressure regulator?
Hi, what fuel pressure regulator is generally used for 8 injector yb engine?
i.e T4, RS500 plenum, 8 greens etc?
Also, where is the best place to buy one?
Thanks in advance, Karl
Old Aug 22, 2010 | 01:15 PM
ybturbo's Avatar
ybturbo
I was told that aeromotive items are really good and durable but they are a bit expensive...
Old Aug 22, 2010 | 01:28 PM
Paul_RS's Avatar
Paul_RS
I got my aeromotive one off the big gay Rainbum. Worked my 8 green fine
Old Aug 22, 2010 | 01:57 PM
VEEDUBBED's Avatar
VEEDUBBED
Make it yourself?,do as i did mate and avoid spending Ł100 or more for an obselete rs500 part.
Just get any Weber FPR and drill out the hole that's already there,tap it and get another barb off a broken FPR and screw it into your FPR,job done.
My custom setup works fine with 8 injectors.
Old Aug 22, 2010 | 02:48 PM
Karl 3dr's Avatar
Karl 3dr
Ok, thanks for the replies, has anyone used fuel lab regulators? Any good?
Karl
Old Aug 22, 2010 | 06:29 PM
AndyPen's Avatar
AndyPen
The standard rs500 item does the job
Old Aug 22, 2010 | 06:52 PM
Fuel lab stuff is good, I have a RS500 one myself though on 4 injectors, I had it so used it, can still get them new afaik.
Old Aug 22, 2010 | 10:57 PM
1374lee's Avatar
1374lee
GGR had the original type in stock but I know he hasn't any at the moment and not sure if they will be getting anymore stock in the future.
Thanks.Lee.
Old Aug 23, 2010 | 12:51 PM
Think mine came from GGR, may well change eventually as want to move it anyway.
timsrs
Nov 13, 2018 11:48 AM
SMILER258
Sep 28, 2015 09:04 AM
Dubs44
Sep 19, 2015 06:31 AM
