Valve springs for high lift
Old Aug 14, 2010 | 08:40 AM
Craigorypeck's Avatar
Craigorypeck
Default Valve springs for high lift
Need valve springs for a N/A cosworth, lift will be 10.41mm on a Newman cam keeping the hydraulic lifters.
Standard cossie springs take a max lift of 8.9ish
Dont want double springs with titanium retainers, or need the spring seating milled out- cannot afford
Has anyone used kents VS30 (opel items) single springs and kept the original retainer.
Apparently these give the same poundage and can handle 11mm lift into the upper 7000rpms. Any info would be great
IainRS1700T
Sep 25, 2015 06:44 AM
RS-Rikki
Sep 21, 2015 07:27 AM
coscor86
Sep 20, 2015 01:21 PM
focuspower
Sep 20, 2015 03:51 AM
focuspower
Sep 19, 2015 08:27 PM
