Picked up my refurbed calipers this morning.. (Pic's)
Old Aug 13, 2010 | 04:33 PM
Big-Dan's Avatar
Big-Dan
Default Picked up my refurbed calipers this morning.. (Pic's)
I discovered the calipers on my car were in abit of a state at it's most recent MOT, my options at the time were ether buy seal kit and fix them myself or have them professionally rebuilt.
I decided to have a go at doing it myself and bought a seal kit from Bigg Red Ltd in Worcester but after seeking advise from a few of you on here it was pretty obvious that I wasn't going to be able to do it myself.
So, last Wednesday I took them upto Bigg Red returned the seals and asked them if they would refurb them for me, I was originally told they'd be ready to pick up Tuesday (10th) morning but the paint didn't arrive in time and they weren't ready till Wednesday.
The calipers were stripped, shot blasted, painted in "post box red" using a special polymer paint and then rebuilt using new pistons, seals, bleed screws etc..
Anyway, here's a couple of pics of what they looked like the day before I dropped them off:
And when I picked them up this morning:
I'm pretty pleased with the quality of the finish, they look and will hopefully feel brand new when I put them back on.
Total cost was £169 for the pair, will be looking to have the rears done as soon as the abs system has been removed.
*EDIT* Quick question, brake fluid, I'm assuming I need to buy DOT 5.1, is that correct?
Big-Dan.
Old Aug 13, 2010 | 04:38 PM
Fordmad!'s Avatar
Fordmad!
They look mint!! I want mine doing!!
I read on there website that it was £119 for a refurb, how come yours cost so much?
Worth every penny though if you ask me, good work
Old Aug 13, 2010 | 04:45 PM
Ryan_3's Avatar
Ryan_3
looking good dan!
Old Aug 13, 2010 | 04:46 PM
Big-Dan's Avatar
Big-Dan
Thanks mate, glad you like them too.
£119 is for standard paint, I went for the Polymer coating (heat cured) as it's brake fluid, road salt and heat resistant.
You can literally wipe them clean if they get covered in shit and they should technically still look new.
http://www.biggred.co.uk/classic.html
Big-Dan.
Big-Dan's Avatar
Big-Dan
Originally Posted by Ryan_3
looking good dan!
Cheers mate
Big-Dan.
Old Aug 13, 2010 | 06:09 PM
You would be better off with a fast road spec DOT4, which will have a higher boiling point being a fast road type fluid, DOT 5 despite what people think was originally engineered for COLD climates, in particular esp and abs systems, where it's lower viscosity was needed.
I would use something like Tarox Road sport, dot 5.1 also absorbs moisture much more readily.
Old Aug 13, 2010 | 07:03 PM
Big-Dan's Avatar
Big-Dan
Hmm, DOT 4 it is then
Can anybody tell me the sequence in which I will need to bleed the brakes? My cars also had a rear disc conversation if that makes a difference at all.
Big-Dan.
Old Aug 13, 2010 | 08:07 PM
fezzajsy's Avatar
fezzajsy
looking good man
Old Aug 13, 2010 | 08:26 PM
escoskmv's Avatar
escoskmv
thay look nice mate.worth every penny. need my rear calipers doin as thay have seen better days.do you have a number for the company in worcs? thanks
Old Aug 13, 2010 | 08:32 PM
RSmech's Avatar
RSmech
order to bleed brakes start with one furthest away from master cyl then next futhest etc...
Old Aug 13, 2010 | 08:37 PM
Big-Dan's Avatar
Big-Dan
Yes mate, company info below:
Bigg Red Ltd
The Workshop
Weir Lane
Worcester
WR2 4AY
Tel: 01905 428793
Fax: 01905 427035
Email: calipers@biggred.co.uk
Website: http://www.biggred.co.uk/
Big-Dan.
Old Oct 28, 2010 | 02:35 PM
RS Grant's Avatar
RS Grant
Made in Scotland
Fitted and working?? Was there a big improvement mate??
Cheers,
Grant
Old May 31, 2011 | 05:54 PM
burnhamshaun's Avatar
burnhamshaun
I know it's an oldish post but what what were they like when fitted and what they like now matey
Old Jun 2, 2011 | 12:12 AM
ram's Avatar
ram
Has a large member
As above. my mate wants to buy my 2wd 4pots off me to fit to his S2 rst but i told him they need quite abit of work to fit as opposed to the 4x4 ones, whats involved as im not sure
Old Jun 2, 2011 | 09:27 AM
Rsmat's Avatar
Rsmat
Looks good mate.
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
DPDISXR4Ti
Ford Fiesta
Sep 21, 2015 03:51 PM
cossirob
Sep 3, 2015 09:17 PM
