fitting a new header tank XR3i
Old Aug 12, 2010 | 04:44 PM
emilyclaire's Avatar
emilyclaire
Question fitting a new header tank XR3i
At the risk of making myself look very very silly , I need to replace the header tank on a mk4 escort XR3i because mine is cracked. Is this relativley easy to do or do I need to take it to a garage?? If any one could give me an idiots guide that would be great as I don't fancy paying ridiculous labour fees if it's something I can do myself with a little guidance. A friend of mine said it's a case of draining it by unclipping a hose at the bottom (I reckon it'll need new jubilee clips because i'm betting they're pretty frickin rusty) unbolting it, unclipping the hoses and then vice versa putting in the new one, is it really that simple???? any help AT ALL would be great
Old Aug 12, 2010 | 05:11 PM
Fordmad!'s Avatar
Fordmad!
Two screws holding it to the shell, undo them. Then just unclip the hoses drain it then put the new one on!
Couldnt be easier!!
Then just fill up, make sure you use anti freeze!!
Old Aug 12, 2010 | 05:23 PM
emilyclaire
Brilliant thanks very much
steerfromdarear
28
Jan 29, 2016 06:14 PM
Gadget
Aug 26, 2015 01:02 AM
Dahl88
Aug 22, 2015 08:16 PM
marky_g
Aug 15, 2015 10:43 AM
155lee
Aug 14, 2015 11:21 AM
