boreing out a yb engine block
Old Aug 11, 2010 | 06:29 PM
dal3door's Avatar
dal3door
Default boreing out a yb engine block
hello just wordring if any one can help me
i need to bore out my cosworth block i have damage on the cylinder
i am making a big bhp engine
has any one now the safe size to bore out to and who will do it
and which block would be better and what is the best compression ratio for big power thanks darren
Old Aug 11, 2010 | 06:40 PM
Mark Shead's Avatar
Mark Shead
What is big power?, Linering is a very good option over 550hp.
Speak to your tuner on comp ratio.
Mark
Old Aug 11, 2010 | 08:54 PM
As above would need to know a lot more details for mark to advise such as turbo/cams etc as a minimum.
How damaged is the block ?
big_Rad
Sep 15, 2017 09:36 AM
James Porter
Oct 28, 2015 12:17 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
Kirstiestar
Ford Fiesta
Aug 17, 2015 07:40 AM
Zoggon
Aug 10, 2015 10:39 AM
