question re Saph braking systems
Old Aug 11, 2010 | 02:57 PM
Kevin_Mc's Avatar
Kevin_Mc
Default question re Saph braking systems
am i right in thinking that on Saph 2wds the front discs are vented, front calipers are 4-pots, the rear calipers are single piston and the rear discs are solid/not vented
whereas
the 4x4s up front have single piston calipers and vented discs and single piston calipers and vented discs at the back?
Is this right? If not, what are the set-ups like and what size are the discs on each of them?
Old Aug 11, 2010 | 04:27 PM
AndyPen's Avatar
AndyPen
Yep you got it right.
Fronts are 310 diameter from recollection... but hopefully someone will confirm as I run 315s these days.
Old Aug 11, 2010 | 04:34 PM
2wd sapph(and 3 door) 283 x 24mm front discs, 4wd are 278 x 24mm, rears are all 273mm, can't remember width.
Old Aug 11, 2010 | 04:37 PM
dojj's Avatar
dojj
Resident Wrestling Legend
2wd is 10mm, 4wd is 20mm
different calipers on the rears to accomodate this but the bearin carriers they bolt onto are the same
Old Aug 11, 2010 | 04:53 PM
You must be younger than me dojj, your memory still works!!
Old Aug 11, 2010 | 05:23 PM
Kevin_Mc's Avatar
Kevin_Mc
brilliant, just what i was thinking then
i knew there were 278mm and 283mm discs but couldn't mind which was which
cheers for the confirmation
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
yatta
May 21, 2016 10:31 PM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
cossirob
Sep 3, 2015 09:17 PM
