Fuel pump hose
Hi, anyone know what hose/fittings I need to replace the pipe between the pump and filter on a 4x4 safe as mine has split?
Cheers Jason
Cheers Jason
Hi,
I used either 16 or 17mm internal bore OPA, about £5 a metre, though I've got loads of it if you want a shorter bit just for this(pm me), think it was that size, on my group a 044 pump.
Hi tabatha are you talking about the tank to pump pipe as that's about the size you say?, my pump tp filter pipe is about 8mm hard plastic?
Cheers Jason
Cheers Jason
JK12
33
Apr 26, 2021 12:09 PM
