Pectel/P8/L8 etc - explain the differences
Old Aug 10, 2010 | 08:01 PM
S1's Avatar
S1
Default Pectel/P8/L8 etc - explain the differences
Can someone explain the difference between all the Pectel options. I'm assuming Pectel T2 is a standalone management but then whats a baby board, is it a plug in into a cossie management?
Who's the keenest on price for a Pectel T2?
Old Aug 10, 2010 | 11:15 PM
B19 JUB's Avatar
B19 JUB
lol all these cossie owners or people running cossie management and no replies.very odd.
id like to know differences too
Old Aug 10, 2010 | 11:30 PM
Big Will_'s Avatar
Big Will_
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
Quick summary:
T2 is a standalone aftermarket engine management system that can be used to run any supported trigger pattern 4 cylinder engine. It is not 'plug and play' into any Ford car and will need a wiring loom making to incorporate as a bare minimum crank sensor, air temp sensor, water temp sensor, throttle sensor, ignition output and 4 injectors.
P8 is the standard ECU found in large turbo escort cosworths, few people who can actually live map the P8 system in the whole country: MSD, Ahmed Bayjoo and perhaps a couple more. P8 runs closed loop fuelling as standard and also runs closed loop boost control. Not quite as 'robust' as a L8 as the adaptive ROM that controls the closed loop fuelling can f*ck up and cause overfuelling problems.
L8 is the standard ECU in a 4x4 Saph and is really the 'preferred' ECU for most. Can be live mapped by a few more tuners, has better processing speed than the L1 or L6 and runs a knock sensor. It is great for most as it isn't as succeptable to 'noise' from poor earths etc. as the P8.
The L8 runs a baby board as standard which is a circuit board about the size as a cigarette packet and carries the EEPROM chip. Some tuners only have the ability to produce chips that work in a Pectel encryption and therefore require you to change to a Pectel baby board.
The P8 does not have a baby board as standard, but again, for some tuners to 'chip' these ECUs, they require a Pectel baby board to be fitted. Sometimes this can be to run additional features such as water injection or ALS.
Any clearer?
Old Aug 11, 2010 | 12:33 AM
S1's Avatar
S1
Originally Posted by Will Pedley
Any clearer?
Yes mate, thats an excellent answer, many thanks!
Old Aug 11, 2010 | 12:39 AM
NoRubNoDub's Avatar
NoRubNoDub
McGarrity Motorsport
And the L8 makes tea although the P8 makes tea but it's abit weak
Old Aug 11, 2010 | 01:29 AM
svony's Avatar
svony
Not to hijack the thread but would it make sense to swap out my P8 for a L8, for the purpose of reliabilty...
Old Aug 11, 2010 | 02:17 AM
wirralphil's Avatar
wirralphil
Ah so the L8 is like Yorkshire Tea and the P8 like Typhoo.
I get ya.
Old Aug 11, 2010 | 07:58 AM
Big Will_'s Avatar
Big Will_
No, not unless you develop running problems which are ultimately diagnosed as being ECU related.
The chips in the ECU are not interchangeable so you'd need to purchase a new chip for a L8 ECU, stick with the P8 for now and only consider a swap if you ever have problems with it
wowk
Mar 30, 2021 07:49 PM
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
SMILER258
Sep 28, 2015 09:04 AM
Sp3no
Sep 27, 2015 07:23 PM
little bram
Sep 27, 2015 07:45 AM
