High Build primer
Old Aug 10, 2010 | 07:06 AM
Cossy Mike's Avatar
Cossy Mike
Default High Build primer
Hello,
I'm at the stage now where I am rubbing back all of the tatty bit's on the underside of my Cossie before paint.
On the spare wheel bowl (under car) after I rubbed it back, it has slight pitting on the metal.
Am I right in thinking - Acid etch then High Build primer over the pitted areas then rub back?
It's just, I was told from the paint supllier to put body colour onto acid ecth after around 4-6 hours whilst it was still tacky and before it cures?
Old Aug 10, 2010 | 07:33 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
if i were u i would remove all the rust
then apply 2 coats of epoxy primer seam seal all seams then smoth stone chip then paint
dont know what your suplier is on about lol etch is ment to be a mist coat to seal moisture then apply 2k primer over it
boeb
Jan 9, 2020 05:11 AM
Kam B
Sep 30, 2015 01:32 PM
