High Build primer over Acid Etch?
Old Aug 10, 2010 | 06:52 AM
Cossy Mike's Avatar
Cossy Mike
Default High Build primer over Acid Etch?
Hello,
I'm at the stage now where I am rubbing back all of the tatty bit's on the underside of my Cossie before paint.
On the spare wheel bowl (under car) after I rubbed it back, it has slight pitting on the metal.
Am I right in thinking - Acid etch then High Build primer over the pitted areas then rub back?
It's just, I was told from the paint supllier to put body colour onto acid ecth after around 4-6 hours whilst it was still tacky and before it cures?
Old Aug 10, 2010 | 07:48 AM
S1's Avatar
S1
Probably because etch is hygroscopic so will start to absorb moisture from the atmosphere if left exposed. There's no reason why you cant overpaint with a high build primer though. Best thing is to get the data sheets for all the paint you're using so you know exactly what you're doing.
Old Aug 10, 2010 | 09:29 AM
xr4x4rs's Avatar
xr4x4rs
any bare metal on the underside you want to have acidd etched really, nigh build prmer is fine on top then colour and laquer if needed
Old Aug 10, 2010 | 11:54 AM
Cossy Mike's Avatar
Cossy Mike
makes sense to me
anyone else come across this, surley I can't be the only one?
Old Aug 10, 2010 | 11:58 AM
RichieST's Avatar
RichieST
I have used high build on top of etch primer when I've been refurbishing scabby alloy wheels and never had a problem!
Old Aug 10, 2010 | 01:31 PM
xr4x4rs's Avatar
xr4x4rs
i took the complete underside of my escos back to bar metal and did what i said above, but before i hih build primered it i sealed with with sealent and brushable seam sealent
link here if you want to see what was involved, carnt remember what page so just scout through them until you see the car on its side
https://passionford.com/forum/restor...0-07-10-a.html
Old Aug 10, 2010 | 03:49 PM
Cossy Mike's Avatar
Cossy Mike
Okay doke, thanks!
I'll have a read through
boeb
Jan 9, 2020 05:11 AM
Kam B
Sep 30, 2015 01:32 PM
