Zetec 2.0 crank and flywheel bolt holes dont line up?
Old Aug 8, 2010 | 07:37 PM
LewisT's Avatar
LewisT
Unhappy Zetec 2.0 crank and flywheel bolt holes dont line up?
I bought a new short block for my 2003 focus i am in the process of building up the engine and once fitting up the flywheel noticed only 5 of the six bolt holes lines up with the old flywheel. the origonal engine was a eddb not sure what the new one is it doesnt have a engine number or code on it was bought of ebay from cgbmotorsport. is it an earlier short block with different flywheel of something, or a manufacturing error
Old Aug 8, 2010 | 07:58 PM
JonathanJ's Avatar
JonathanJ
the bolt holes are offset so the flywheel will only fit in one position on crankshaft, try turning it slowly to see if they line up.
Old Aug 8, 2010 | 09:22 PM
LewisT's Avatar
LewisT
after i posted i tried just that got it to line up on a further note is it a ford job to get new flywheel bolts?
Old Aug 9, 2010 | 05:48 AM
JonathanJ's Avatar
JonathanJ
Ford do say to replace bolts when replacing flywheel , so much so that if you have to do it under warranty and you do not replace them then they throw the claim out ......whilst it is off you might aswell as you do not know if overtightened before so a good idea .
Old Aug 9, 2010 | 12:10 PM
Sp3no's Avatar
Sp3no
Definately change the bots Ł1.40p each from ford, or you could get ARP's for about Ł27
Old Aug 9, 2010 | 03:22 PM
LewisT's Avatar
LewisT
went to ford the day never had any then minimum order 25 , luckily he managed to find some at another dealer.
Old Aug 9, 2010 | 09:24 PM
Sp3no's Avatar
Sp3no
What!! thats unbelivable i have never come across the minimal order thing i mean how many times do you swap your fly wheel out lol. Glad you got it sorted
JoeyBoyden
20
Aug 22, 2015 03:23 PM
JoeyBoyden
14
Aug 15, 2015 09:51 PM
Gadget
Ford Escort RS Cosworth
Aug 14, 2015 07:19 AM
Gadget
Aug 13, 2015 08:19 PM
Bosch
Aug 4, 2015 05:14 PM
