oil covered spark plugs :(
Old Aug 8, 2010 | 04:46 PM
problem circled's Avatar
problem circled
Default oil covered spark plugs :(
First of all, Hi everyone im new here
Secondly,
I was given a tired 1.8 escort si
Let me start by saying the car is thought to have done almost 300,000 miles!
I pulled the plugs to replace them.. when I pulled the ht lead from cyl 1 i noticed it was full of oil, as was cyl 2 & cyl 4 ... cyl 3 was dry
Im hoping this is all to do with the rocker cover gasket.. but as you will see the actual parts that go into the engine are a bit shocking too! also, all those deposits on the thread!!!! (perhaps the plugs look so bad cause the oil dripped down as i was removing them)
1st plug as i removed it (the worst)
the cool kid gang
working from left to right
1st cyl
2nd cyl
3rd cyl
4th cyl
I heart high milage fords
Old Aug 8, 2010 | 05:00 PM
rich123's Avatar
rich123
well first it looks like those plugs have been in the car from day 1 lol deffo been in there a long time,if it runs and drives sweet enough i wouldn,t worry high milage like that your going to see this sort of thing
Old Aug 8, 2010 | 05:05 PM
problem circled
yeah it runs and drives decent enough, it has the crap idle problems that zetecs are famed for but i have narrowed it down to a duff maf!
Old Aug 8, 2010 | 06:54 PM
LHD220Turbo's Avatar
LHD220Turbo
probably down to worn rings, a comp will probably tell you the same thing
at the end of the day, if it still runs alright then dont worry about it; i personally woulndnt of even bothered changing the plugs
Old Aug 8, 2010 | 07:06 PM
Fiddy's Avatar
Fiddy
do zetec's not have rubber O rings on the underside of the rocker cover round the spark plug holes to stop this ?. forgot to put mine in when i changed the rocker covers on mine, and i got a bit of oil on the plugs till i fitted the O rings.
Old Aug 8, 2010 | 07:07 PM
COLEYST200's Avatar
COLEYST200
rocker cover gasket look at your socket
Old Aug 8, 2010 | 08:35 PM
RichieST's Avatar
RichieST
Thats probably just from the oil in the plug well that has soaked the plug when you pulled it out. Stick a new rocker cover gasket on and a new set of plugs and it'll be fine!
Old Aug 9, 2010 | 03:48 PM
None of those plugs have been burning any appreciable amount of oil, they would be very covered in deposits if they had, just sort the r/c gasket.
Old Aug 9, 2010 | 06:30 PM
gav.rst's Avatar
gav.rst
sounds like worn piston rings engines are cheap enough at scrapyards 4 you it done good for milage but if it goes ok drive it til it dies.
wheelwizardrefurbs
Sep 24, 2015 08:35 PM
stevierob
Sep 7, 2015 07:09 PM
rog
Sep 4, 2015 07:24 AM
hopper350
Sep 4, 2015 12:53 AM
StephTell
Sep 2, 2015 06:31 PM
