what to look for on an Evo 4??
Old Aug 8, 2010 | 03:40 PM
Gadget's Avatar
Gadget
Spanner monkey
Default what to look for on an Evo 4??
Quite fancy an Evo but only really got 4 money to spend out. I've not got a clue on them, never owned anything other than Fords.
Anyone had any experience, or could tell me what to look out for on them.?
Cheers, Gary
Old Aug 8, 2010 | 06:28 PM
gtir1281's Avatar
gtir1281
http://www.lancerregister.com/faqindex.php
look for rust on the rear struts and crankwalk
john
Old Aug 8, 2010 | 06:37 PM
MrBroadside's Avatar
MrBroadside
As above crankwalk, when driving if clutch pedal moves is a sign of it, also make sure AYC works as pump can be quite common, make sure AYC comes on when ignition on, does it's check then goes out.
To check AYC fluid it's in the boot on drivers side, didn't have any issues with mine just get a boost controller on it, uprated fuel pump and a Map
Hope this helps
Old Aug 8, 2010 | 06:55 PM
gup's Avatar
gup
ill have a word with the blokes at work gary as i work for mitsi now
Old Aug 9, 2010 | 03:54 PM
Gadget's Avatar
Gadget
Spanner monkey
Cheers chaps, will have a search about and see what i can find out about them.
Old Aug 9, 2010 | 06:36 PM
turbo_3dr_tommy's Avatar
turbo_3dr_tommy
Hope this helps
and Injectors
great cars mate check the above and have a good luck underneathe as loads are rotten but look ok
Old Aug 9, 2010 | 06:45 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Forget the 4, get a 5. If you can't afford that, wait until you can IMO.
Old Aug 9, 2010 | 06:56 PM
wozzy's Avatar
wozzy
+1
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
IainRS1700T
Sep 25, 2015 06:44 AM
wheelwizardrefurbs
Sep 18, 2015 02:39 PM
YODI
Aug 30, 2015 01:12 PM
TomPengelly
13
Aug 22, 2015 06:38 PM
