recaros
any one know how these come apart ?
got a set of mint leathers and i do mean mint except the drivers seat seems to be from a lhd as in the winders are both on the left hand side of the seat i have got another set of leather which is not nice at all and i have heard you can take the seats apart and make them the correct hand . any one done this and can offer advice ??
Hi, they can be stripped and rebuilt using basic tools, but i warn you its not a 5 minute job. you would be best using the best and correct seat frame that you need, and retrim it using the best leather from either seat. all the panels come off seperately. base cushion, 2x base side bolsters, back-sides are one panel and back cushion all undone by unclipping wires and plastic end trims. the headrests are removed by removing 2 large r-clips from the gap above the rear cushion approx 2-inches below the front of headrest. the rear bolster/seatback unclips from the bottom below the hinge-line. bolsters are held by wires running vertically behind the rear cushion, which is held by a horizontal wire in said gap by headrest clips. also it would be a good time to find and replace the seat mat that splits on the base. hope this helps.
Adam Graham
Sep 6, 2015 06:04 AM
borboyous
Aug 22, 2015 11:17 AM
