HELP!!!
Old Aug 7, 2010 | 08:38 PM
Fordmad!'s Avatar
Fordmad!
Default HELP!!!
My xr3i has a knocking noise from the engine when coasting or when your not on the accelerater but fine when braking or with your foot down!
I think its the driveshafts as both have a little bit of play in them, will it be okay to drive to Ford Fair and back 250 miles??
Old Aug 7, 2010 | 08:51 PM
phil_focus's Avatar
phil_focus
if its a worn joint then you may get away with it for a while. i've had a vibration for 6months + that turned out to be nackered drive shafts and Sandy off "The Garage" had a nackered nocking drive shaft for ages. when he eventually took it appart the tripod bearings all fell apart
just drive it jently
Old Aug 7, 2010 | 08:58 PM
Fordmad!'s Avatar
Fordmad!
Aslong as it gets me 2 Ford Fair and back i don't care what happens after that haha!!
Old Aug 7, 2010 | 09:01 PM
Ebonycossie4x4's Avatar
Ebonycossie4x4
have you got AA if so who cares.... just drive it!
Old Aug 7, 2010 | 09:02 PM
Fordmad!'s Avatar
Fordmad!
No AA or breakdown recovery good old trusty tow rope and two mates in there cars....I should be fine!!
Old Aug 7, 2010 | 09:03 PM
Ebonycossie4x4
youll be fine mate, you cant use a rope on motorway though... it could be a long way home!
Might See you there tommorow. Unless the M5 breaks down that is.
