S1 turbo running problems
Old Aug 7, 2010 | 06:37 PM
performace_ford's Avatar
performace_ford
Nae Bither!
Default S1 turbo running problems
Got S1 rs turbo when idle its seems its running lumpy as if it was running 3 cyclinders but its not it revs in neutral but dies when i try to run it under load any one had this problem or has anyone any ideas cheers
Old Aug 7, 2010 | 06:43 PM
waynefrst235's Avatar
waynefrst235
Hi. Does it drive at normal acceleration or does it just cut out as soon as you try to drive?
Wayne
Old Aug 8, 2010 | 10:02 AM
performace_ford
Nae Bither!
just as soon as you try and drive it to dies
Old Aug 25, 2010 | 08:13 PM
gingejp's Avatar
gingejp
Check all your hoses to make sure there are no air leaks. RSTs don't like them due to mechanical fuel injection. Would prob still have problems with no load too though but check anyway.
If your fuel pump is worn would also do this. They often get quite noisy when on last legs. A garage should be able to check your fuel pressure for you or you can buy a gauge and check it yourself if confident. Fuel pressure should hold good throughout rev range but with kaput pump it will drop off causing engine to die like running out of petrol.
It could could be quite a few things to be honest though but worth looking into those two for starters.
Old Aug 26, 2010 | 09:36 AM
I would start by checking the CO at idle, if this is wrong and very lean the rest will be, and will give the symptoms you have.
Do also check all the pipes for any loose ones as advised as you should do this anyway.
big_Rad
Sep 15, 2017 09:36 AM
3i Jim
Nov 20, 2015 05:12 AM
Churtz
15
Aug 13, 2015 06:40 PM
Zoggon
Aug 10, 2015 10:39 AM
turbobill
Aug 9, 2015 05:21 PM
