KA Sport Lambda Sensor
Old Aug 6, 2010 | 09:03 PM
dickie_junior's Avatar
dickie_junior
Default KA Sport Lambda Sensor
Hi guys,
I don't really want to ask this question, but I need a quick fix!
My other halfs KA Sport SE has it's engine management light on, got it checked today and it's the Lambda sensor that's reporting the problem. We was quoted £130 to fix it! Trouble is tomorrow the car is going to a garage to be traded in! The fault diag has already cost me £35, I don't really want to spend out £130 more!
Is there any way of 'bodging' the lambda sensor so the light does off?? Or is my only option to replace it??
Old Aug 7, 2010 | 07:22 AM
oldford's Avatar
oldford
Depends on the exact fault code. If the Oxygen sensor is reporting a mixture failure there's nothing wrong with the sensor and replacing will not cure the problem.
Do you know the number of the code read?
Old Aug 7, 2010 | 04:01 PM
dickie_junior
Hi, Thanks for replying, the fault code was read by a diagnostic tool, said sensor 1 bank 1.
I was attempting to remove the sensor, but in the end, just gave up and replaced it! Only cost £56 for a new sensor, Thought the £130 quoted by the garage was a bit much!
Car's been properly fixed now!
On the down side, fog light glass has gone (stone hit it) So that's on order as well! I hate cars! >;o(
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
