Brake caliper bolt..
Old Aug 6, 2010 | 06:09 PM
:hEnNiKeR:'s Avatar
:hEnNiKeR:
Bam Bam Bam
Default Brake caliper bolt..
Hey guys,
Just tried replacing my gf's front pads on her fiesta and some absolute numpty grease monkey has rounded the bottom bolt on the caliper .
It's an allen key bolt with a rubber sleeve around it.
What are my options? Ive tried smashing a size up allen key socket on it and it's having none of it.
Were not massively flush right now so a garage is the last resort.
Helps please
Old Aug 6, 2010 | 06:16 PM
danb21t's Avatar
danb21t
mole grips
Old Aug 6, 2010 | 07:47 PM
JamesyRS's Avatar
JamesyRS
very small socket, had same problem with my bros audi and done it this way but gotta be a strong socket so does not split when you hammer it over the head of bolt! bit daft but if it works it works try make it a 12 point socket also not the 6 point get a tighter hold hard but always worth a go with it being circle!
Old Aug 7, 2010 | 08:20 AM
If all else fails, or if you don't have enough room to get other things to work just drill out head.
Old Aug 7, 2010 | 05:08 PM
cabriolet's Avatar
cabriolet
use a torx socket whack it in undo it bobs yr whatever
Old Aug 9, 2010 | 07:02 PM
spunknik's Avatar
spunknik
Heat up the threaded end, and then use mole grips! Should be a 7mm allen key head.
Nov 1, 2015 06:53 PM
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
