Running probs
My mates escos won't rev properly past 4k I starts poping and missing
Any ideas what it might be?
PassionFords Creator
If its a Weber version on P8 then its most likely in limp home mode which is a probably sensor failure. Have an expert plug into teh ECU and analyse the datastream.
K plate big turbo. It's been on a diagnostic machine today and is picking nothing up. But been told that the engine loom plug corrodes on them so we are going to give them a clean and try that.
Not my car but the things that have already been checked:
phase sensor condition and gap:0.2mm
Plug gaps: 0.6mm
New rotor arm and cap
New leads
CPS gap 0.8mm
Car will pull past the 4000rpm but appears to misfire until through.
car is running greens and a chip, boost is currently 20psi peaking at 22psi.
Headgasket has recently been changed.
Plug gaps: 0.6mm
New leads
CPS gap 0.8mm
just looking on youtube and found this mate.when it gets to near 4k revs it misfires
says the wires to the phase sensor wire was reversed,may happen if the wire is broken in standard way round
http://www.youtube.com/watch?v=khjbJ...eature=related
mine did this running thing a few months ago it was a corroded wire to the tps i replaced it and instantly cured!!!! BUT its just started playing up again
this time its reving up and down constantly, just put a brand new iscv on today and still the same?????????????????? any one got any ideas?????
Just wandering if a cossi is in limp mode how do you clear it?????? disconnect ecu???
I'm hoping it does'nt return when it's rebuilt.....
Eigdoog
Sep 13, 2015 05:46 AM
