Hard to start
Old Aug 5, 2010 | 09:54 AM
3dormatt's Avatar
3dormatt
Default Hard to start
Hi all. I have a really annoying problem that I can't seem to cure. The Car is an Escort; but, it is running the engine, loom, ecu, and running gear from a 2wd Saff, hence why I thought it should go in here!
The car; when hot or cold, usually turns over for a good 5-10 seconds before it will fire and start. Maybe 1 in 15 times it will start on the button. The saff that I pulled everything out of started on the button; even after being sat for a couple of months!
The only things I have changed since doing the conversion are the injectors and chip; however I have tried the old chip and it made no difference. The injectors were bought second hand and I am told they were reconditioned, plus the car drives perfectly so I have no reason to doubt them atm.
I have changed the cps, ect, act, coil, plugs and checked and double checked the wiring and am now completely stumped!!!!!
Please help.
Matt.
Old Aug 5, 2010 | 10:12 AM
oldford's Avatar
oldford
What you probably didn't change was the fuel pump.
Try this: ignition on, but do not start! Wait 2 seconds for fuel pressure to build up and then start the engine.
If that works then the pressure drops without the pump running. Usually a defective fuel pump.
Old Aug 5, 2010 | 10:21 AM
3dormatt's Avatar
3dormatt
Yep! Brand new uprated fuel pump, rewired from the battery back; and brand new fpr.
Old Aug 5, 2010 | 05:51 PM
Get the injectors checked, I've had one that was iffy when cold but perfect once running, but could be a lot of things.
Old Aug 5, 2010 | 06:05 PM
oldford's Avatar
oldford
Or have a local garage perform an exhaust gas test.
Then you know what is going on during cranking and cold running and that's probably cheaper than checking injectors.
Old Aug 12, 2010 | 02:28 PM
3dormatt's Avatar
3dormatt
Sussed it 2 leaking injectors!
mk22door
49
Mar 26, 2022 07:15 AM
Fordmad!
Sep 26, 2015 05:24 PM
kevin36
Sep 2, 2015 06:24 PM
oilman
Trader Parts for Sale.
Aug 30, 2015 08:37 AM
