ST170 loom connection
Old Aug 5, 2010 | 12:34 AM
Ester170's Avatar
Ester170
Default ST170 loom connection
Hello everybody,
this is my first post, so be gentle with me, hehehe.
I have recently had the head rebuilt on my ST170, the problem is, for love nor money can I find where this plug goes???
I don't know how to attach a pic so I will describe it.
It's a very short thin 2 wire grey plug in the same loom as the temperature sender in the top of the thermostat housing.
Infact it looks similar to the thermostat housing temp sender.
The big label stickered to the loom reads
2M5V-9H589
AD
Any ideas would be greatly appreciated,
thankyou
Old Aug 5, 2010 | 12:41 PM
Sp3no's Avatar
Sp3no
This any use?
Old Aug 6, 2010 | 01:20 AM
Ester170's Avatar
Ester170
Hiya Mate,
thanks for a quick reply and the pic.
YES! I have now found it thanks to you.
The part of the loom is not clear in the pic, if you follow up from the temp sender you can just about see another loom dissapearing behind the head. (hence why I couldn't find it).
This goes to the Knock sensor, it was a bit of a tight job to click to two plugs together, infact I removed the fuel rail to gain enough access.
Having said all this, without you pic I would of still been scratching my head!!!
Thanks again mate
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
Mark RS
Oct 12, 2015 06:01 AM
muz
Sep 30, 2015 08:29 AM
stevecfrst1
Sep 30, 2015 05:18 AM
Marv888
Sep 26, 2015 03:44 PM
