Problem with keys...
Old Aug 3, 2010 | 05:35 PM
Muttley's Avatar
Muttley
I am The Stig.
Default Problem with keys...
Just wondering how to solve my problem I've just bought new batteries for both my keys and none of them seem to want to open or lock the doors with the remote now with one of my keys it's a little bit worn on the metal it will lock the door but not unlock it...and I get a little paranoid about perhaps locking the key with good metal in the car (it's happened before!)
Is there any way I can get them to work again I've tried to make the car "learn" the RF frequencies again by following advice from someone saying you've got to switch it from 0 to II on the barrel 4 times remove key and press a button but none of that works...any ideas?
Old Aug 6, 2010 | 09:08 AM
kitted_escort's Avatar
kitted_escort
http://cgi.ebay.co.uk/ford-steering-...item1c0ab57bd3
just read the bottom bit. i dont live that far from them so i dont use the ebay bit i just go in there shop.
Old Aug 6, 2010 | 09:57 PM
martysmartie's Avatar
martysmartie
That "Someone" is right when you replace the batteries the ECU sometimes needs to relearn the key again (Not immobiliser, just remote side)
You have the correct procedure as well turn key to position 2 and off four times within 3 seconds, this activates "Learn" mode, this is signalled by the LED illuminating continuously, this happens for 20 seconds in which time you have to press a button on the key this, this will flash the LED once is successful. When done leave it will quit after 20 seconds have elapsed anyway, alternatively turn ignition back on.
Martin
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
