koni shock absorber refurbishment
Old Aug 2, 2010 | 06:22 PM
155lee's Avatar
155lee
Default koni shock absorber refurbishment
i bought a set of old konis which have never been fitted to a car but have been kept in a dry garage for a few years.i went to adjust them today as they are a bit soft and 1 of the adjusters was stuck.you could feel the shaft turn a good bit so its obviously stuck at the bottom,so i got a shifter and tried that but the end result is its still seized and now the bit you adjust it from has broken off.can i send it away to be repaired?if so where too?ta,lee
Old Aug 2, 2010 | 06:29 PM
adam151082's Avatar
adam151082
Id ring or email Koni and explain the situation
Nov 1, 2015 06:53 PM
Rod-Tarry
75
Oct 13, 2015 04:44 PM
SMILER258
Sep 28, 2015 09:04 AM
rog
Sep 4, 2015 07:24 AM
