Garage clearout, 2wd Cossie bits,
The original Rouge Trader
All of this is used,
2wd engine mounts, £5
2wd rear diff mount, £5
1x yokohama A520, 205 50 15, 7mm tread, no damage and was a spare, £20
Koni adjustable front and rear shocks, with Ahmed springs( supposidily) and adjuster, £100
2wd "Monster" big wing sump, was bought from someone on here, will not fit a standard cossie set up due to the front bowl size, £100.
Coilover springs, rear 12" 200Ilbs, suit Avo CO, front 8" 350Ilbs 65mm ID, suit Leda, £25 for all 4
2wd gearbox plastic spacer thingy, £5
2wd rear spring rubber boot thingy, £5
Allow navigaters footrest, £10
RS Ownersclub footmats, set of 4, £10,
Would prefer collection on the larger stuff, but will send (it will be quiet expensive) or you can arrange a courier yourself, or come and get it, im at Maidstone in Kent, ME15 8AS, and im only 5 mins away from Jcns 7&8
Steve.
Steve.
Oct 9, 2015 07:38 PM
TrevCos
Alloy wheels and ICE for sale
Sep 13, 2015 02:12 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
