Uprated Fan switch and standard rad?
Right rather a strange 1 but i was wondering if any is running 1 of stus uprated fan swith on a standard rad???
Ive just ditched my ally rad n gone back to a standard rad with a standard fan switch,
Problem is im struggling with temps but not in the normal way, my fans are now cutting in at 85c n not cutting out till 75c,
now in my opinion this is a little to low!!! i would much rather the fans cut in about 90ish but cut back out about 79ish,
I have a uprated fan switch sitting in my tool, box that used to be in my ally rad, i was wondering if this would solve my issues or would this raise the bar to much n the chance of the fans cutting to Late?
Cheers jay?
Cheers jay?
Uprated Radiator fan switch for All Sierras.
This switch will usually switch on your fans at around 90 Deg C and Off again at around 87Deg C
It works the best and closest to those temperatures in an uprated alloy radiator, but it is a good upgrade for normal radiators too in my experience, working around 93/90 in std radiators.
this was taken from stu's ad on ebay for his uprated switch.
saff is working!!!...atm
i just have my std rad n fans running off a switch in the car.......easy......car gets hot...turn them on for 20/30 seconds.....as long as ur doing about 40mph the car cools it's self
thanx 4 the replys.
I will give the up rated fan switch a go!
Personally i prefer the fans on to be controlled by the fan switch, it leaves less to chance n eliminates human error!
1 slip n u have a engine boiling mud
The bog standard "uprated" fan switch will be fine, actually better as the hysteresis is much smaller, personally I would never chance the temp by switching manually, as you say only need to forget once and it could be a expensive mistake, but I do have a warning light for my fan/s.
I have put a blue led in the top left corner of the rev counter to come on with the fans, just gives a bit of reassurance, and looks pretty too, should have used a pink flashing one!!
liamT74
Sep 23, 2015 10:24 PM
Adam Graham
Sep 6, 2015 06:04 AM
